Farmall 300 Tranny Fluid Change?
Posted by mmccarrell on February 02, 2009 at 07:11:42 from (63.117.229.132):
I am needing to change the oil in the tranny and differential of my 300 but the problem is there is about 3 drain holes. All of which had nasty stuff come out. There also seem to be 2 check holes on the "driver" side of the tranny. So the question is where do I put the new grease in and what check hole do I use? If someone has a picture that would be sweet otherwise a description is fine too. I've changed a lot of fluids in small tractors but this one with a dozen hole has me confused. Thanks in advance!
