Re: Farmall 300 Tranny Fluid Change?
Posted by pete 23 on February 02, 2009 at 07:26:32 from (173.87.1.12):
In Reply to: Farmall 300 Tranny Fluid Change? posted by mmccarrell on February 02, 2009 at 07:11:42:
You can fill through the rear hole on the side if you like but there is a 3 hole cover on top of trans cover if it is a farmall model, can't remember on the utility. The deal on the front plug on left side is the oil will slowly fill to that level so let it sit a bit after filling to level on rear hole as you may need to add a little more . The original idea of front hole was (you were supposed to fill to the front hole level if the tractor was standing on an incline during stationery work)so just basically ignore it. You may want to flush it out a bit. I know it is expensive to just throw away oil now days but I would put in about 5 or 6 gallons of diesel fuel with one gallon of oil and drive it around a little,drain , then fill with fresh hy-tran or hy-guard fluid.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
