Re: Super A PTO adapter
Posted by Janicholson on February 02, 2009 at 15:00:18 from (199.17.6.128):
In Reply to: Super A PTO adapter posted by F-I-T on February 02, 2009 at 14:04:49:
An OR clutch is very importantAs a child, I learned the necessary tricks to avoid issues, but it is so unnecessary to learn tricks when the clutch is the solution. A machine shop could mill the diagonal hole needed for a bolt to be used for retaining, if none can be found with the spring loaded pin. JimN
