Re: What year is this Farmall
Posted by LMack on February 03, 2009 at 14:13:24 from (74.190.6.60):
In Reply to: What year is this Farmall posted by nick thomas on February 03, 2009 at 09:43:48:
The motor number is stamped on the right side of the engin block behind and above the distributor on a flat almost directly behind the throttle rod at the very north end of the block. Most 100's were made around 1955. Look for the actual unit serial number on an aluminum plate that should be on the inside of the right seat support or it could be on the left side of the cluch tube. Once you have the number you can find other information from links on this page.
