Re: What year is this Farmall
Posted by Hugh MacKay on February 03, 2009 at 15:45:18 from (209.226.106.3):
In Reply to: Re: What year is this Farmall posted by LMack on February 03, 2009 at 14:13:24:
L Mack: Farmall 100 serial numbers are on left side of clutch housing. The engine serial number is directly below No.1 spark plug however that will not help. Farmalls 100 and 200 each have their own sequence of serial numbers starting at 501. The engine however share a common swquence of serial numbers.
Farmall 100-501 had engine number 572, 200-501 had engine number 663, I-100-501 had engine 976. By the end of production in 1956 Farmall 100-18940 had engine 35930, 200-15698 had engine 34131. The last I-100 was 635, no listing of engine, but as you can see, only 135 built.
Interesting at this point 130 and 230 each start over at 501 and engine numbers continue where 100 and 200 left off. Same occurs when you go to 140 and 240, engine numbers continue where 130 and 230 ended.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
