Re: 560 Gas thermostatic valve spring
Posted by Janicholson on February 04, 2009 at 17:37:22 from (64.83.193.190):
In Reply to: 560 Gas thermostatic valve spring posted by Chris NW Ind on February 04, 2009 at 16:52:01:
The flap is to be open when the engine is cold. The open flap allows exhaust to circulate in contact with the outside top of the intake manifold. As the riser thermostatic spring heats up, it relaxes allowing the flap to close blocking the flow of exhaust toward the intake.
The flap should be pushed toward closed by the exhaust. It should be pushed towasd open by the thermostatic "spring". The diagram just does not quite get to the clarity to show the spiral direction. Best of luck, JimN
