Re: 560 Gas thermostatic valve spring
Posted by pete 23 on February 04, 2009 at 17:53:22 from (173.87.1.12):
In Reply to: 560 Gas thermostatic valve spring posted by Chris NW Ind on February 04, 2009 at 16:52:01:
The heat riser spring should be about 1/4 turn of tension holding the counterweight in the vertical position when engine is cold. The conterweight should spring right back to vertical when pushed forward, and it will stay that way until warmed up some. Notice the ofset slot in end of shaft and spring also for correct alignment.
