Re: Farmall A Radiator Drain
Posted by Jim Becker on February 04, 2009 at 19:35:55 from (71.252.139.51):
In Reply to: Farmall A Radiator Drain posted by Doug Barnette on February 04, 2009 at 16:45:33:
The difference in the drains is to deal with the difference in the housings. The B and C housings are squared off for the front implement mounting pads. The 45 elbow, long nipple and cap reach down to a drain hole out the bottom.
The bottom of the A housing runs at an angle. The access hole through the housing is directly in line with the hole in the engine's inlet elbow. A plug directly into the elbow is easily reached. I couldn't say for sure without looking at a tractor, but as I recall a pipe of much length in the drain could be hit by the front axle.
