Re: Farmall A Radiator Drain
Posted by ScottyHOMEy on February 04, 2009 at 19:59:39 from (64.222.201.63):
In Reply to: Re: Farmall A Radiator Drain posted by Jim Becker on February 04, 2009 at 19:35:55:
Thanks for jumping in, Jim. Could you tell I was thrashing??? '8^) I'm feeling like JimN here, and will be ponderin' on it half the night. Likely will run over and have a look at Neighbor Dave's A in the morning.
For the meantime, I just took a look at the drawings for the A chassis, and suspect you're right on the money. I hadn't thought of the axle being set back so far (as compared to the way it sits out front on my SuperC). I know that if the nipple were any longer on my BN, the tires would come into play.
If the plug is easy enough to get to, Doug could go that route, keeping things simple, and get his cooling system filled.
Again, thanks!
