Re: C221 Engine on 205 Combine
Posted by bc on February 06, 2009 at 07:18:03 from (68.88.175.43):
In Reply to: Re: C221 Engine on 205 Combine posted by noncompos on February 05, 2009 at 22:05:04:
noncompos, Just wondering what all engines your catalogs show for the 2606. Mine has what appears by the paint (the industrial tractor is all yellow except for the bright red engine) to be a replacement engine. I've kinda assumed it is a C-263 by the larger carb size (IH carb with 1 3/8" throat while most others have a 1 1/4" throat). I haven't been able to match the block casting numbers to anything. The I&T manual lists for the 606, 2606 a C-221 with a 1 1/4" throat on the carb and also lists for the 560, 660 a C-263 with a 1 3/8" throat on the carb. That is how I arrived at assuming it was a C-263.
I can dig out the block casting number if anyone can match it. The case dealer couldn't through their system. Thanks.
