c-123 piston pin bushing
Posted by jonathan mirgon on February 06, 2009 at 12:22:25 from (207.69.137.39):
Do the c-123 replacement rod piston pin inserts have to be machined to obtain proper clearance or are they a press them in and go design ? Just wondering if the rod insert replacements will require machine shop work ?
