jonathan mirgon said: (quoted from post at 13:22:25 02/06/09) Do the c-123 replacement rod piston pin inserts have to be machined to obtain proper clearance or are they a press them in and go design ? Just wondering if the rod insert replacements will require machine shop work ?
Piston pin bushings are a press fit in the rod. After they are pressed in they should be burnished which involves pressing a special tool through the bushing to expand it to insure a tight fit in the rod. After burnishing they will be about .010 smaller than the pin. They need to be honed to .0002 clearance. When properly fit, with the pin and bushing lubed with 30 weight oil, when held with the pin vertical, it should slowly slide through the bushing with just its own weight.
The crankshaft bearings do not require any machining but the big end of the rod must not be distorted. they do need to be matched for proper size with the crankshaft.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
