Re: Farmall A starting problems
Posted by El Toro on February 06, 2009 at 17:13:46 from (64.12.116.73):
In Reply to: Farmall A starting problems posted by Doggonetractors on February 06, 2009 at 16:41:16:
The float may be set too high and it may have a pin hole in the float causing it to sink. Check the float level and shake that float to see if any gasoline can be felt sloshing. That float needle valve may not be shutting off the fuel. Hal
