Farmall A starting problems
Posted by Doggonetractors on February 06, 2009 at 16:41:16 from (24.93.248.174):
I just purchased a 1946 Farmall A. The engine was completely rebuild with dome pistons wich gave it 24 HP at the PTO on a dino test. The head has new valve guides and the valves ground. Tractor does not smoke at all. My problem is starting this beast. I go to start it and it acts like its flooding. Tractor trys to run like the fuel is burning but not burning fast enough. After going through this a couple of times I finally get the tractor started. Am I starting wrong? Whats is the best way to start this thing? Carb was rebuilt and I always shut the gas off when tractor is not running. Please help.
