Re: Farmall A starting problems
Posted by Brownie 450 on February 07, 2009 at 04:31:25 from (216.51.158.151):
In Reply to: Farmall A starting problems posted by Doggonetractors on February 06, 2009 at 16:41:16:
Sounds like distributor timing---but, if timing is right---I'd pull the valve cover & see what the valve clearance is. You might have to adjust the lash.
