Re: Farmall A starting problems
Posted by Red Mist on February 07, 2009 at 05:39:00 from (67.142.130.12):
In Reply to: Farmall A starting problems posted by sr1988 on February 06, 2009 at 16:41:16:
Doggonetractors said: (quoted from post at 17:41:16 02/06/09) Am I starting wrong? Whats is the best way to start this thing? Carb was rebuilt and I always shut the gas off when tractor is not running. Please help.
Best way to start a 113 Zenith equipped engine is by not using the choke at all, if possible, under your local weather conditions.
Your float level may be off a little as others have mentioned. If it puts out black smoke when you get it running, that is a sure sign. In that case, readjust your float level initial setting to where is is just a little more than spec calls for - a "skinny" 1/8" more. That will cut the gas off in the bowl at a little lower level.
mike
