Farmall 300 Transmission Fluid Change?
Posted by mmccarrell on February 08, 2009 at 08:18:10 from (24.2.117.134):
third party image
I posted a picture to help out with where I am talking about. I drained some nasty grease from all three drain plugs on the bottom of the tranny. All told I got about 7 gallons or so out. I then removed the fill plate on the top of the tranny by the gear shift and added until it ran out of the check hole. (Red Arrow) The problem is nothing came out of the (yellow arrow) check hole by the clutch rod. I noticed a drain? hole (white arrow) that seems to be in the same area the the small plate in from of the belt drive is in. The question is how do I fill the front of the tranny? (yellow) because when I added a bit of fluid past the TA plates it went right out the (white arrow). Do I fill it using the check hole? Please help, I"m terribly confused.
