Re: Farmall 300 Transmission Fluid Change?
Posted by mkirsch on February 09, 2009 at 06:55:47 from (64.80.108.55):
In Reply to: Farmall 300 Transmission Fluid Change? posted by J.J. on February 08, 2009 at 08:18:10:
Correct. The white hole is not a check level plug, and is in a different cavity from the yellow hole.
Notice the red hole and the yellow hole are at the same level.
IIRC the yellow hole is up in the cavity where the live PTO gear is.
