Re: 450 Farmall power steering
Posted by redrider on February 08, 2009 at 18:38:02 from (66.235.45.149):
In Reply to: 450 Farmall power steering posted by Chris NW Ind on February 08, 2009 at 17:38:34:
My first question is did the tractor come from the factory with power steering? If it did not then it sounds to me like there is something missing in the installation. First let me explan how the factory power steering works. The pressure regulator and the first hydratouch valve is different than a tractor without power steering. There also is a plug to block hydraulic flow into that first hydratouch valve. The regulator has a bypass tube going to the bottom of the first valve which supplies hydraulic flow to all three hydratouch valves. This is done to give the power steering priority over the hydratouch valves. The reason the powersteering works when you pull a valve lever is there is no place for the pressure to go and is forces through the power steering unit.
I hope this answers your question.
RR
