Re: 450 Farmall power steering
Posted by Chris NW Ind on February 08, 2009 at 18:50:21 from (64.136.26.226):
In Reply to: Re: 450 Farmall power steering posted by redrider on February 08, 2009 at 18:38:02:
I did some digging thru my parts catalog and found that plug between the first valve and the big casting. I'll check for that tomorrow. If that doesn't pan out, I'll have to conclude that the priority valve is plumb wore out. Then I need to figure out how to tie in an aftermarket priority valve.
As far as I know the power steering is factory. All the piping is there, including the bypass to the 1st valve.
We'll see what tomorrow brings.
Chris B.
