806D injector sleeve
Posted by SDdave on February 08, 2009 at 19:49:59 from (208.53.219.210):
I was hoping you could give me a little advice on my 806. I was taking the injectors out to be serviced, and with my good luck the last one popped out the injector sleeve too. I have never put an injector sleeve in with a head on the motor. Can it be done? I have always taken them to the machine shop and had them do it, but it was usually always more than one that came out.I did check the compression on this tractor and it is around 320-330 so it is a little low , so if the head comes off the next question is should I go for overhauling it? I really didnt want to right now but if I am in it that far ?? any of your guys thoughts would be appreciated
