bc , don't quite know where to send you from here. Does the other hydraulics work ok or aren't you using any like loader etc.If your aux valves work ok pump is not problem. Hitch has seperate pump riding piggy back on main pump. I am going to assume you have checked filter and fluid levels, is system noisy. I would put the two lines that go into steering cyl into a bucket and you should get about 3 gal flow per min when turned in each direction. You could have bad relief valve, (located opposite end of the T screw) or even a steering valve that is blocked as there is a plastic check valve in there, or maybe the spool in steering valve doesn't move.It is mounted right on the flow divider valve assembly with lines going to steering cyl. Now I have you totally confused. Good luck.
Today's Featured Article - Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo.
... [Read Article]
Latest Ad:
[More Ads]
