Thanks Pete. No you didn't confuse me. The IH 3000 loader and backhoe work fine. No hitch. Plenty of hydraulics there. I just want to eliminate the flow divider and the pilot valve before buying a pump. The steering valve/hand pump works ok and works manually as well. If that is a relief valve behind the flow divider, then I'll try to pull it out assuming there is room to get to it. There isn't much room to work on it. Might be a spring project to pull it and the pilot valve out and go through them. I suppose there could be a busted spring, oring, or something.
I've pulled the main line from the pump to the top of the flow divider and it definitely puts out the fluid.
I thought I fixed it last fall when I found a piece of metal (maybe a piece of broken spring) under the check ball of the relief valve located in the empty draft control housing. But that just helped a little bit. Put it in a vise to compress the ball and the metal piece fell back into the relief valve.
Thanks and I didn't mean to hijack this thread but some of these hydraulic issues are similar.
Today's Featured Article - Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo.
... [Read Article]
Latest Ad:
[More Ads]
