Re: 300 hunting problem
Posted by Bob M on February 10, 2009 at 09:30:40 from (151.190.254.108):
In Reply to: 300 hunting problem posted by nate long on February 10, 2009 at 09:00:28:
Sounds like a chronic lean condition under high vacuum. Cause could be a vacuum leak (leaking carb to manifold gasket, manifold to head gasket or a crack in the manifold) or a plugged carb idle circuit.
Quick test: While the engine is hunting slowly close choke. If you find a choke position where the hunting stops it's a lean mixture problem.
If that's what you find, next identify the cause: With the engine hunting CAREFULLY spray a bit of starting fluid at the carb and manifold gasket areas. If the idle changes briefly you've found the leak. Otherwise you need to open the carb again and work on (clean out) the idle circuit.
