Re: 300 hunting problem
Posted by pete 23 on February 10, 2009 at 10:44:48 from (173.87.1.12):
In Reply to: 300 hunting problem posted by nate long on February 10, 2009 at 09:00:28:
Some times when you put carburetors back on the alignment to gov is not perfect, I like to loosen the bolts and screws where tube from carb to gov fastens so as to allow them to seek their own alignment. Then adjust the internal link so pin goes in freely with throttle wide open and carb wide open.
