Re: Super A - battery terminal really hot
Posted by Kurt in VABeach on February 10, 2009 at 10:47:32 from (198.49.157.12):
In Reply to: Re: Super A - battery terminal really hot posted by Hugh MacKay on February 09, 2009 at 13:38:32:
thanks Hugh, that's may be it. when I pull the starter lever, it is really hard to pull, and barely wants to crank over, but in the past, it has always fired up within one crank, so never a problem. I bet the moisture in the air has messed with the switch and it is now sticking. the amount of heat on the terminals seems like what you see in a short, or as Bigdog pointed out, a bad connection. I'm going to put the charger on the battery, and clean up all the connections including taking the switch apart and cleaning or getting a new one. The one on it looks like it has been there for a number of years. I have only had the tractor about 2 years. Thanks again.
kurt
