Re: Super A - battery terminal really hot
Posted by Hugh MacKay on February 10, 2009 at 13:52:13 from (209.226.106.105):
In Reply to: Re: Super A - battery terminal really hot posted by Kurt in VABeach on February 10, 2009 at 10:47:32:
Kurt: If this situation is not wearing your battery down, then I suggest as Bigdog did, BAD CONNECTION. Bear in mind the bad connection could be within that starter switch. You can get the same results with too small battery cables, and there is very little difference between too small cable and too small connection. That too small connection could be at either end of either battery cable or within the starter switch.
What happens with these switches over time, terminals wear down from arcing every start. You can clean terminals, however that will usually be short lived as there is no adjustment to move terminals closer to each other. When you remove that switch, be careful not to loose the two guitar pick type insulators. I find cleaning the terminals give you two weeks to 6 months to buy a new switch. It might not help at all.
