Re: Farmall H trans deck removal. 1948 H
Posted by Theman on February 10, 2009 at 14:18:32 from (63.107.135.35):
In Reply to: Farmall H trans deck removal. 1948 H posted by narrowfarm on February 10, 2009 at 11:49:26:
There are three dowel pins lining up the deck to the case. They may be stuck. Two are on the right and left between the axle housings and brake drums. The other is on the right side of the belt pulley gearbox opening. The deck has to come up fairly straight. I had too use sheet metal shims - didn't want to mar the gasket surface - to jack the deck from the broken bolt that had cemented itself in place from 55+ years of dust and rainwater.
