Re: Farmall H trans deck removal. 1948 H
Posted by narrowfarm on February 10, 2009 at 16:07:23 from (173.52.69.10):
In Reply to: Re: Farmall H trans deck removal. 1948 H posted by Theman on February 10, 2009 at 14:18:32:
Theman, i had my deck up about 1 inch at at the belt pulley gear box end.The one bolt that is boken flush is at the rear of the tractor in the very center.I can get just a very small narrow air gap in the back by the broken bolt.The broken bolt is what is holding her up.It has a broken drill bit in it now(1/16")What do you mean by jacking up and exactly what point is safe to jack.I tried heating and hammering by the broken bolt.I really would like to remove the deck if possible. thanks john
