smta front end
Posted by J Thomas on February 11, 2009 at 16:39:43 from (208.124.79.252):
Hey guys we are trying to use a smta front end on our super m but our front steering shaft is now two short about 2inches . I thought the ta's were longer in the transmission area does the front steering box set out farther ? This is an ffa project and the front end was donated for this basket case tractor Thank you Jerry
