Re: smta front end
Posted by Janicholson on February 11, 2009 at 17:05:24 from (66.173.50.44):
In Reply to: smta front end posted by J Thomas on February 11, 2009 at 16:39:43:
The bolster (front end) is farther forward. The hood will not fit either. A pipe and (quality weld can extend the shaft, but the hood must come from a MD, SMD SMTA. The MD hood is (I believe the correct length but the hole is wrong RF instead of left center). An appropriate fan extension. or mods to the shroud might work. I have not thought about it, but drilling new frame rail holes might work. (be careful with this last answer, it might cause other drastic issues to become horrible.) JimN
