Re: 53 Super M Will Not Start
Posted by El Toro on February 12, 2009 at 07:51:09 from (64.12.116.73):
In Reply to: Re: 53 Super M Will Not Start posted by Scott Dobbins on February 11, 2009 at 13:45:01:
You should be able to start the tractor by holding your hand over the throat of the carburetor unless you're not getting gas to the carburetor. Open that main jet adjusting screw to see if that helps. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
