Farmall 560 power steering
Posted by FARMALL 560 on February 13, 2009 at 06:27:08 from (71.0.81.214):
I'm having trouble with the power steering control valve. The end plate that is held in by a snap ring blew out. I replaced oring seal and snap ring with same results. Appears that there is pressure where it should not be. Would this most likely be caused by problem in control valve or worm unit?
Thanks
