Re: Farmall 560 power steering
Posted by bc on February 13, 2009 at 13:13:37 from (68.88.175.43):
In Reply to: Farmall 560 power steering posted by FARMALL 560 on February 13, 2009 at 06:27:08:
I can't imagine how the snap ring would blow out unless it isn't seating to start with. I'd start with checking the snap ring groove to make sure it isn't full of felt, rubber, and crud not allowing the snap ring to seat fully all the way around. That seal may not be going in far enough to where it doesn't allow the snap ring to seat.
Might get a dental pick or wire or something to clean out the groove and then try fitting the snap ring in a time or two before you put the seal in.
Can't rule out that the snap ring groove may have been dinged up a little and it might take a file or die grinder to clean it up. Snap ring might have a bad edge that doesn't allow it to go into the groove.
