M Carb Question
Posted by Too Far Gone on February 13, 2009 at 12:29:18 from (67.221.197.94):
Ive just put it back together.It hasnt run for awhile.Give it new rings and rod bearings.Pull the choke as soon as you let it off it'll start,then immediately die,just wont stay running.The carb is getting gas seepage around the bowl gasket.If its sucking air there would that cause problems like a manifold gasket does?Thanks for any replies.Rob
