Re: F14 starting problem
Posted by J.J. from Afton on February 15, 2009 at 21:22:38 from (139.225.248.182):
In Reply to: F14 starting problem posted by Doug Steinbach on February 15, 2009 at 17:15:26:
Well I have not had one with a broken weight or pawl. I did have to replace the whole impulse assembly on the F-4 mag on my F-12. This was because the two pins carring the weights on the disc were so badly worn that one weight would actually fall out of line every so often and lock in place. Than to unlock it Id have to spin it backwards. But what you are saying makes sense to me, as each weight should have a tab to trip the impulse. So the impulse should be tripped twice for every revolution of the mag drive.
-Jordan
