Re: Gears
Posted by mkirsch on February 16, 2009 at 08:00:57 from (67.240.251.254):
In Reply to: Gears posted by Farmall Bob on February 16, 2009 at 04:11:42:
Even with the smallest possible drive gear and the largest possible driven gear, you can't get a low enough low to handle a tiller. The tractor needs to move at less than a literal crawling pace.
I've always wondered if a good machinist could build a gear reduction that fits in the torque tube. There's a long input shaft from the clutch to the transmission, plenty of room for a planetary reduction gearbox.
I suppose you could just leave the tractor in neutral, ride the brakes, and let the tiller pull you forward, but that is a lot of work and a very rough ride.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
