Gears
Posted by Farmall Bob on February 16, 2009 at 04:11:42 from (24.31.133.90):
Hi,
Does anyone get into their transmission and change the gears to make the speeds different? I would like to make the speed for 1st gear slower for the possiblity of using a roto-tiller. Thanks!
Bob
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
