Re: Gears
Posted by Wardner on February 16, 2009 at 09:14:30 from (4.154.246.58):
In Reply to: Re: Gears posted by Mark on February 16, 2009 at 08:04:48:
third party image
Mark, I am in the process of collecting parts to "creep" a 650. It involves installing a second countershaft in the transmission. It will be powered with a hydraulic motor. I will need to buy an off the shelf spur gear and build an air shifter. Everything will fit inside the transmission. The "stealth" installation would probably not work on smaller tractors due to space. On other tractors (H and M), you might have to hydraulically power the belt pulley or one of the bull pinions. It would have to be quick detachable or use some sort of dog clutch.
It just takes a little math and the performance tables from the hyd motor mfg to figure it out.
