Re: Gears
Posted by vinmann on February 16, 2009 at 22:13:05 from (75.132.199.194):
In Reply to: Gears posted by Farmall Bob on February 16, 2009 at 04:11:42:
I was wondering about something similar.
Farmall 350, wanting to mount a trencher tool to it. Could the TA be modified so it acts as neutral when activated and then power applied to the belt pulley with a hydraulic motor? Would the engine driven oil pump suffice or should I put a larger one on the PTO driven tool?
Next could a similar set-up be done with a 56-86 series using a PTO driven hydro pump and motor from a combine and tied into the transmission through the front wheel assist output ? Would a front wheel output from a snoopy fit a 856 0r 756?
Vin
