Re: Farmall A valves
Posted by ScottyHOMEy on February 17, 2009 at 06:14:35 from (71.241.194.79):
In Reply to: Re: Farmall A valves posted by Janicholson on February 17, 2009 at 06:03:14:
Okay, we were typing at the same time again. LOL!
Still, I guess I'm missing something. I'm guessing the gas head would have a smaller cavity/headspace requiring the longer valve stem to get down to it? Is that extra length (or lack of it) enough that the issue is mating/alignment/wear between the rocker surfaces and the ends of the valve stems when the clearance is set?
