Posted by Janicholson on February 17, 2009 at 06:42:18 from (199.17.6.128):
In Reply to: Re: Farmall A valves posted by ScottyHOMEy on February 17, 2009 at 06:14:35:
I didn't check the part numbers, I just have experience with the two heads, Dist/gasoline, they do not have interchangable valves. The difference between the two are obvious. If there is just a few thousandths difference it may be that the thickness of the new valve at its head/margin (rim between face and flat of head) is thicker, a good thing. The use of Dist valves will hyper extend the spring, and not work with the geometry of the rockers at all. Soooo I think you were correct and I was on the wrong topic. A gasoline head would still be desirable if there is a choice. Thanks JimN
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
