Re: Did International forget rear axle grease fitting?
Posted by SASmith on February 18, 2009 at 03:46:55 from (72.18.51.122):
In Reply to: Re: Did International forget rear axle grease fitting? posted by scotc on February 17, 2009 at 18:17:14:
Thanks for the replies.
But the Hy-Tran doesn't leak past the inner seal. The inner seal is the kind with a thin rubber-coated spring wound around the axle and no fluid gets past it. The axle and housing between the inner seal and the outer bearing was dry. It's been dry for quite a while and I've been keeping the transmission full.
There is no bearing cap. On the axle from the outside in is the wheel hub, an oil seal and the bearing and that sits against the bearing cup. Then there is about 18 inches of axle until the inner seal.
The local dealer service manager insisted that the axle should be dry and there should be a grease fitting on the end of the carrier. There is no fitting and no obvious place to put one.
Would the International Service Manual have instructions on keeping this bearing greased?
Thanks again.
