Re: Did International forget rear axle grease fitting?
Posted by scotc on February 17, 2009 at 18:17:14 from (206.16.201.166):
In Reply to: Did International forget rear axle grease fitting? posted by SASmith on February 17, 2009 at 17:18:44:
Yeah, the rear end lube comes out if the seals are going bad, so some HAS to be getting to the bearing.
I thought that the grease fitting on the axle caps was to keep the seal lubed and sealing?
