The small wire on the starter is hot when the key is turned to start only. At all other times it is dead. The jiggling you did temporarily made the connection. The fault will very likely come back. Why did you OIL wires!? Using some corrosion inhibitor, or silicon spray on the wires at the connections after serious cleaning is OK, but oil, never. Best of luck, the issue is either in the IGN switch, or a terminal. See the posts on the JD forum. JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
