Re: Did International forget rear axle grease fitting?
Posted by Randy-IA on February 18, 2009 at 16:06:09 from (207.177.83.77):
In Reply to: Re: Did International forget rear axle grease fitting? posted by scotc on February 17, 2009 at 18:17:14:
The grease fittings on the letter tractors was there to keep the dust/dirt shield (felt washer) lubed -ONLY. The outer bearing is lubed by the main frame oil which is kept inside by the outer oil seal which is inboard of the felt washer. Don't have any knowledge of the tractor in question. ...Randy
