Re: Slow Farmall Tractors
Posted by Wardner on February 21, 2009 at 14:25:36 from (4.154.243.157):
In Reply to: Slow Farmall Tractors posted by Farmall Bob on February 21, 2009 at 12:59:42:
Check the thread below. I did the math on various M-450 sized tractors concerning first gear speeds and ratios. These will also apply to H-350 tractors although the ratios will be slightly different.
Slowest pre 450 Farmall tractor will have 560 ring and pinion, 560 first, TA low, small tires, and 660 planetary axles. I am guessing top speed in low range 5th would be around 8 mph. I have done all that to a SMTA with the exception of the 660 planetaries. It's kinda hard to hide those.
I suppose if you messed around with the camshaft, installed electronic ignition, and used a smaller carb, you might get an engine that would run well at 200-300 rpm. Don't know how long it would last.
