Posted by the tractor vet on February 23, 2009 at 07:52:49 from (75.19.120.250):
In Reply to: 1486 steering posted by Don Anderson on February 23, 2009 at 07:48:55:
Sounds like the trunnion , bushing and pin need replacing . They have a kit to repair this . Get undwer the ft. end and wiggle the cylinder and you will see what is loose . Takes about 2 hours to fix .
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
