Posted by Don Anderson on February 23, 2009 at 07:48:55 from (24.116.133.2):
The steering on my 1486 is becoming a worry driving on the road. The front tires get to wobbling back and forth in unison. I am wondering if it has something to do with the seals in the steering cylinder since the pitmans and ball joints appear to be tight. It is hard to tell driving down the road. My main concern is that something will break driving down the road and I will end up someplace that I do not want to be. Even turning on rough ground in the field there appears to be a lot of slop but at least if something would break there I am going slow enough to avert disaster. Thanks for any suggestions.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
