Re: Farmall B Timing
Posted by Eric Skokan on February 23, 2009 at 15:55:00 from (71.212.136.110):
In Reply to: Re: Farmall B Timing posted by Bob on February 23, 2009 at 09:32:32:
well first a friend and i made a crank because there was none when i bought it Then I reset the rotor spindle to the mag gear lining the R on the rotor spindle to the notched tooth on the mag gear (because the rotor spins clockwise) I hand cranked the motor to tdc on compression stroke Then I replaced the cover, rotor, cap, etc. But no dice. It doesn't fire.
So, I pulled the #1 plug and turned it over to see if it would spark. But no spark. (does it have to be grounded really well or perhaps not at all?) I just layed it on the govenor.
I'm wondering which direction to look next. I'm thinking I either did a poor job of finding TDC and have the timing wrong or somehow I've caused the magneto to not generate a spark. How does one test a magneto for spark independently of the timing of the engine? Also, I've noticed that the magneto wants to trip a few degrees after where I think TDC is. Is that normal?
By the way, thank you all for the help thus far. I am very greatful.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
